JD 425 - Only running on 1 cylinder when cold, and picks up cylinder 2 after 1 min.
   / JD 425 - Only running on 1 cylinder when cold, and picks up cylinder 2 after 1 min. #11
Last year my JD z915 started popping and backfiring it would do it when the engine was cold or hot. I took it to the dealer since it was still covered under the warranty. They said it was a bad ignition coil. They replaced it and I haven稚 had anymore issues. Hope this helps
   / JD 425 - Only running on 1 cylinder when cold, and picks up cylinder 2 after 1 min. #12
The ignition modules are notorious for being temperature sensitive. I had one that was just the opposite: ran great until it got hot. You could swap the one's you have and see if it moves to the other side. Then you'll know for sure.
   / JD 425 - Only running on 1 cylinder when cold, and picks up cylinder 2 after 1 min. #13
I would recommend replacing both. I wouldn't be surprised if the OP disconnected one of the spark plug wire and it doesn't matter which one it won't start on the other cylinder.
19011 (A48082)
19011 (A48082)
2017 Ground Hog HD99 Towable Hydraulic Auger (A49461)
2017 Ground Hog...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
Bus (A50323)
Bus (A50323)
40ft Shipping Container (A49461)
40ft Shipping...
