JD 4240 Battery maintainer connection placement
   / JD 4240 Battery maintainer connection placement #11
All 3 variations of JD 4240's have 12 volt electrical systems
   / JD 4240 Battery maintainer connection placement #12
Easy to confirm. Measure from positive to ground on each battery. If one reads 6 volts and one 12, it's a 12 volt system and has to be charged across the two series batteries.
   / JD 4240 Battery maintainer connection placement #13
Not really. If you read from positive to negative on each battery both would read six volts. However if you read from the positive of one to the negative of the other it should read either 12V or 0V if they are series connected. In a series connection the positive of one battery is connected to the negative terminal of the other.
   / JD 4240 Battery maintainer connection placement #14
I agree with KennyG. Measuring voltage positive to ""ground"" as he stated isn't the same as measuring positive to negative on each battery.
   / JD 4240 Battery maintainer connection placement #15
Agree. Ground is not necessarily negative on a multi battery system. I could have been more clear on my statement.
   / JD 4240 Battery maintainer connection placement #16
Your posts was clear enough imo. And correct.
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A55315)
Galvanized...
Kubota L4701 (A53317)
Harley Davidson (A56859)
Harley Davidson...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A57880)
2019 TOYOTA...
