JD 4210 E Hydro Loadmatch issue
   / JD 4210 E Hydro Loadmatch issue #1
jdgreg
Warrenton, Va
My 4210 eHydro hesitates only when the Loadmatch is engaged. I've read here that maybe resetting the CPU (remove positive for >1 min) may fix it. Any other suggestions? TIA
   / JD 4210 E Hydro Loadmatch issue #2
My JD4410 load match does not work well with low RPM, must be in the higher operating RPM range. Have you checked the old threads probably a lot written over the years. Good Luck ---Fuse
   / JD 4210 E Hydro Loadmatch issue #3
I shut mine off on my 4310 and never turned it back on. It is the most useless thing I have ever seen on a tractor I owned.
   / JD 4210 E Hydro Loadmatch issue #4
I like it, but it really only shines when I use it with eThrottle enabled. Then the engine speeds up as you press the peddle down, so it all works very smoothly. I have heard that eThrottle is only available on the 4520 and 4720... which sucks:thumbdown:
Yeah, I've searched here, but havent come up with a lot. And yes, the rpms are not too low.
   / JD 4210 E Hydro Loadmatch issue #6
good luck getting to work right i took mine back so many times and heard so many different lines of bs from the dealer till i finally took it and traded it for the same size but with a power reverser tranny .
I tried pulling the pos battery terminal for 5+ min this weekend, still did it. I'll drop by the dealer this weekend and see what they say.
   / JD 4210 E Hydro Loadmatch issue #8
Try pulling out and cleaning the flywheel sensor. May help.
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2006 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2006 FORD F750 XL...
2008 FREIGHTLINER M2 106 (A53843)
2008 FREIGHTLINER...
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
Case 950 8 Row Air Planter (A53473)
Case 950 8 Row Air...
