JD 4210 - bogging down ?
   / JD 4210 - bogging down ? #1
kidsdad5
Burnt Hills, NY
Kubota BX2200
I have a new to me 2003 4210 with ehydro trans - 815 hours. It's bogging down going up a small incline while mowing relatively short grass. The indicator light is flashing 3 short and one long. Is this something electrical? It also slows down a bit even when not mowing, not as bad, and I don't get the indicator lights unless I am mowing. Confused and hoping there is an easy remedy?
   / JD 4210 - bogging down ? #2
Are you familiar with all the different ehydro settings on the 4210?
I am not anymore, but recall that some of them can be a bit confusing and conflicting.
:welcome: to TBN
I am still trying to learn all the ehydro settings, yes they are somewhat confusing to me too. Thanks for the link to that thread, missed that one when I attempted a search. Since I have no idea what a potentiometer is (I do now after researching) I'm probably going to have to contact a dealer. Reading that info leads me to believe it's not something I can repair. Hopefully I can find an ehydro settings combo that will work. Thanks for the replies. If anyone else has other thoughts or ideas I would appreciate hearing them. Thanks
   / JD 4210 - bogging down ? #5
kidsdad
What gear range are you mowing in, when you sense the lack of power?
beenthere - I was in B. I also tried C and it did the same thing.
   / JD 4210 - bogging down ? #7
Will have less HP in high "C" range, should have more in "B" range and more yet in "A"
"C" is only for road travel.. no engagement of attachments.
Are you using "load match" ?
Also look for something causing more load.. bearings? grass or wire wound around spindles? brake dragging?
Thank you. Will spend some time reading my manual in detail tonight. I just got the tractor and started cutting grass............Something tells me the brake may be sticking, pedals and park brake seem to function in an odd manner. Tomorrow I'll check these and the other items you mentioned. Love the help found on this forum. Thanks again
   / JD 4210 - bogging down ? #9
I personally don't like the "long arrow" mode at all in the little I've driven a 10 series. It make the transmission feel like it's being controlled with a rubber band. The short arrow is much more responsive.
   / JD 4210 - bogging down ? #10
The 4210 was underpowered, but the 4310 was not bad. I have the next generation (3x20) and there is no power in range C--transport only. A or B only for using the PTO or engaging ground. Also the torque curve peaks around ~1700 rpm, so if you are dragging under there you definitely will feel a power drop-off.
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
Chevrolet Tahoe SUV (A52377)
Chevrolet Tahoe...
40ft Shipping Container (A52377)
40ft Shipping...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2005 Manac AAF-48 50 Ton Flatbed Equipment Trailer (A51692)
2005 Manac AAF-48...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
