jd 4200 running rough
   / jd 4200 running rough #1
raps9201
john deere 4200
I have a jd 4200 that starts fine runs at idle up to 1500 rpm fine but go over that and it starts sputtering-rpms drop and sometimes quits all together and I can restart it at idle and run fine after a couple of seconds. Could this be due to some crud in the fuel tank blocking the outlet. I have replaced all the fuel hoses and filter and still doing the same thing. any help would be great. Thanks
   / jd 4200 running rough #2
Sounds like a piece of SOMETHING getting sucked into the fuel tank outlet. In my case it was a piece of silicone gasket that had come adrift from my hand pump. When it quits, take a quick look at the rubber hose TO the fuel pump, the suction might collapse it for a minute.
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A46684)
2019...
2011 Nissan Murano SUV (A46684)
2011 Nissan Murano...
2000 Toro Workman 3200 Utility Cart w/ Body Mounted Hydraulic Scissor Lift (A46684)
2000 Toro Workman...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A47371)
2017 Ford 550 XL...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A46683)
2021 John Deere...
Digmaster DM100 Mini Excavator (A49251)
Digmaster DM100...
