JD 4200 dies when put in gear
/ JD 4200 dies when put in gear #1
joe0054
I have a JD 4200, Problem is tractor dies when put in gear. Had a problem with the safety under the seat so I wired direct, tied wires together,(bypassing it). Didn't change anything, wires together or apart no difference. Had this problem once before and unplugged, repluged the seat safety switch and that fixed the problem then but not now.
Thanks for any help on this.
Joe0054
/ JD 4200 dies when put in gear #2
Joe, that definately sounds like the saftey switch again. Maybe check the wiring. Sometimes wiring problems can drive you crazy.
Sincerely, Dirt
Thanks,Dirt < pulled the wires off the pressure switch under the seat, wired them together, still dies, left them apart, still dies (when pushing in clutch and placing in forward or reverse)Tractor will start with circut open or closed.Tractor has safety switch on transmission. when unpluged will not crank to start.
Thanks for your help
Joe0054
/ JD 4200 dies when put in gear #4
May I assume there's only 2 wires to your seat switch ?
And the seat switch 'does not' send either wire to ground when active ?
Do we have a wiring schematic handy ?
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A59231)
2023 Fat Truck...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
