JD 4120 crab walk
   / JD 4120 crab walk #1
youngpg
Has anyone had any experience with their JD 4120 doing the crab walk on slippery ground? My 4120 will have the back end start quickly going to the side as if the back is trying to pass the front on slippery (muddy, gravelly, even if almost level) ground. Scary next to a steep drop off. Any ideas what the problem is?
   / JD 4120 crab walk #2
With/without loader?
Which tires? Ag/turf/r4
Do you have weight on the rear of the tractor? Tire ballast/wheel weights/weight on 3-point?
Front wheel assist engaged/disengaged?
   / JD 4120 crab walk #3
Any kind of side slope in mud the rear will chew it's way down hill, especially with the diff lock engaged.
A 4wd with the fronts pulling will do a bit better but the rear will often still work down hill.
1981 Chevrolet P30 Box Truck (A50860)
1981 Chevrolet P30...
2012 GALLEGOS TRAILER 130BBL VAC TRAILER (A50854)
2012 GALLEGOS...
F-800 POWER PUMP 800 HP TRIPLEX MUD PUMP POWERED BY 3412 CAT ENGINE (A50854)
F-800 POWER PUMP...
2025 K0520 UNUSED Welded Wire Mesh Roll (A50860)
2025 K0520 UNUSED...
Tandem Axle Rear Truck Frame (A48081)
Tandem Axle Rear...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
