JD 4110 3 pt hitch won't drop
   / JD 4110 3 pt hitch won't drop #1
RGC426
JOHN DEERE 4110
Good Morning All,
My jd 4110 3 pt hitch won't drop, I checked the flow control and it opened all the way and they won't drop. I have not used the 3 pt since last fall when i raked my driveway. I did put the rake on hoping the weight would help lower it but nothing. So then I thought I would loosen the 2 bolt holding the flow control to the case and relieve the presure to lower the 3 pt and it did lower. I then tightened the 2 bolts back up to the flow control. I started the the tractor and raise the 3-pt back up and it would not lower again. Any suggestions??? Is my flow control valve bad? Any help would be appreciated.
   / JD 4110 3 pt hitch won't drop #2
Good Morning All,
do you have a draft control lever??? i know with my kioti if i have the draft control in use, my 3 point wont drop.
   / JD 4110 3 pt hitch won't drop #3
Answered other post...please don't post the same question in different forums-it makes it very hard to help you.
sorry about the double post wasn't sure which one was the best to post in.
I pulled the flow control out and disassembled and didn't see anything (debrie) or broken or scored parts...any ideas. Hate to buy a new valve if it isn't the problem ($800. valve)
7 ft. Rotary Cutter & Log Splitter (A50860)
7 ft. Rotary...
2025 25ft. 800Amp Extra HD Booster Cables (A48081)
2025 25ft. 800Amp...
2002 International 9200i Truck (A51039)
2002 International...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2014 Kenworth T400 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A48081)
2014 Kenworth T400...
