JD 4110 3 pt hitch won't drop
   / JD 4110 3 pt hitch won't drop #1
RGC426
JOHN DEERE 4110
Good Morning All,
My jd 4110 3 pt hitch won't drop, I checked the flow control and it opened all the way and they won't drop. I have not used the 3 pt since last fall when i raked my driveway. I did put the rake on hoping the weight would help lower it but nothing. So then I thought I would loosen the 2 bolt holding the flow control to the case and relieve the presure to lower the 3 pt and it did lower. I then tightened the 2 bolts back up to the flow control. I started the the tractor and raise the 3-pt back up and it would not lower again. Any suggestions??? Is my flow control valve bad? Any help would be appreciated.
   / JD 4110 3 pt hitch won't drop #2
Good Morning All,
do you have a draft control lever??? i know with my kioti if i have the draft control in use, my 3 point wont drop.
   / JD 4110 3 pt hitch won't drop #3
Answered other post...please don't post the same question in different forums-it makes it very hard to help you.
sorry about the double post wasn't sure which one was the best to post in.
I pulled the flow control out and disassembled and didn't see anything (debrie) or broken or scored parts...any ideas. Hate to buy a new valve if it isn't the problem ($800. valve)
UNUSED Safety Traffic Cones (A50860)
UNUSED Safety...
Head Rack / Running boards (A50860)
Head Rack /...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
3-Point Spreader Attachment (A50860)
3-Point Spreader...
2014 RAM 5500 FLATBED TRUCK (A51222)
2014 RAM 5500...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
