JD 4105 transmission fluid / filter change
   / JD 4105 transmission fluid / filter change #1
Scott Y
Brookings, S.D.
JD 4105 / Ford 6610
Hi, new to the sight, I have a JD 4105 with 290 hrs. just dumped the tranny fluid, removed suction filter assy. need some help here, do you just clean the metal suction filter or do replace it? about $75, I have been told you can just clean it? looks like new from the outside , but if it needs to be done so be it, there is an inline filter as well, that I will just clean the screen. I take it you might as well buy actual JD hy -guard oil , not the farm supply oil? Thanks for any help, winter is coming trying to get it ready for action.
Thanks
   / JD 4105 transmission fluid / filter change #2
You just clean the screen. I suggest going with JD hydraulic fluid.
OMLVU19126_A9
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
Pallet Fees (A50775)
Landoll (A50657)
Landoll (A50657)
