JD 4105 third function loader not working-
   / JD 4105 third function loader not working- #1
tassiedevil
Glaziers Bay Tasmania Australia
CK 20 Hst
Hi all, I have just re attached my loader after some months and for some reason the 3rd function is not opening the bucket- is there a fuse for this function or is is it purely a hydraulics problem maybe?
I must admit the tractor doesn't get allot of attention these days but it would be good to find out if this is a straight forward problem.
Thanks in advance.
Matt
   / JD 4105 third function loader not working- #2
Check for voltage at the solenoid first while activating the button. But ,I suspect the spool in the valve body is stuck from lack of use, not an uncommon problem. Post some pics of it and we can try to help.
   / JD 4105 third function loader not working- #3
G'day Cobber!
I've had a similar (or, perhaps, the same problem) with my 4105's FEL 3rd function.
If your 4105 is from "Midland Tractors", the 3rd function is an 'in house' addition. My neighbour was able to hunt down the fault and it turned out to be the valve in the block not seating.
My 3rd function fault has since returned. I, like you, am in no hurry to have it corrected as I rarely use my 4in1 bucket.
G'day Cobber!
Thanks for the reply
Sorry about delay, and thanks for the feedback @kennyd I’ll take a few shots of the loader and get a few more details, still managing at this point with out it. Would like to resolve it at some point .. 👍🏻
G'day Cobber!
Hey Wagtail yes it is from Midland, I purchased second hand from a dude in Launceston, all working as it should for a few years then after a long period without use it stopped working - I think I know what you mean I’ll look into it- cheers @Wagtail
   / JD 4105 third function loader not working- #7
That's what happened with mine. When it stopped working, you could still 'hear' a slight 'click' when you engaged/pressed the 3rd function button on the joystick, but no longer was there a solid 'thunk'... all from the 3rd function block mounted on the right hand FEL arm.
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
2008 Genie S-65 65ft Telescoping Boom Lift (A53421)
2008 Genie S-65...
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
Brush Bandit 200UC (A52377)
Brush Bandit 200UC...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
