Grading JD 4100 with 5" Box Blade
   / JD 4100 with 5" Box Blade #1
Jimnfireman
Thompsons Station, TN (Williamson County - Gorgeou
John Deere 4100
After picking up a 5' Bush Hog Box Blade for a JD 4100, I am experiementing with what we can do. It makes for a great counter balance for the FEL. But more than that, I would like to get better at grading. Filling in behind a retainer wall, I want to smooth out the top grade. Can I allow the BB to basically "float" across the top. My draft settings seem to lock in. I realize the draft is meant to dig into the ground, but can we soften that up a little? I feel sure the equipment will do it, the operator however, may be a little unskilled. :confused:
   / JD 4100 with 5" Box Blade #2
Without seeing what is actually happening, I am going to GUESS. I would guess the box is tilted forward and digging very aggressively in to the dirt. I would recommend to purchase a hydraulic top link. This will allow you to "adjust on the fly" the angle the box is operating at. Tilt forward for digging and back to lay down dirt. Level to level out a drive way etc.
There is no hydraulic down pressure on the 3-pt on the 4100. The tractor has really no action in how the blade performs besides the power to pull it. Search hydraulic top link for hours of reading fun!
   / JD 4100 with 5" Box Blade #3
Jim - you should be able to float the BB by adjusting the 3 point arms. If you have your operator manual you should be able to see how. Basically the lower arm has a slip lock that changes from float to locking. The pin pulls out and turns 90 degrees to make this switch between float and lock. Good luck.
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
Year: 2013 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 79843.5 Plate: Body Type: 4 (A53422)
Year: 2013 Make...
UNUSED SDLANCH SDLE20 MINI EXCVAVATOR (A57192)
UNUSED SDLANCH...
Hay Spear (A56469)
Hay Spear (A56469)
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
(2) HYD CYLINDERS (1) 3" X 24" & (1) 3" X 12" (A57192)
(2) HYD CYLINDERS...
