Mid-Mount Mower JD 4100 to JD790
   / JD 4100 to JD790 #1
Xjdigger
Lincoln Maine
John Deere 5300
I'm looking to buy a John Deere 790 and sell my John Deere 4100 and want to know if my 60 inch mower deck will switch over to the John Deere 790.
Are there any difference in mounting from the 4100 to the 790?
   / JD 4100 to JD790 #2
I am quite sure all the mounting hardware will be different, but you can search around JDParts: Unsigned Landing Page to be sure.
Does this 790 have a mid-PTO? It was an option on that machine.
   / JD 4100 to JD790
Thanks for your reply.
The 790 does have the mid PTO but in a different position.
What I am thinking is that I could take the mounting hardware off the 4100 and put that on the 790.
The question is whether it would bolt up?
   / JD 4100 to JD790 #4
Probably not a direct fit and if you have r1 fronts of of 7.0-14 along side of 12.2-24 rears, or if you have r4's of 25.8.5-14 fronts with 15.00x19.5 rears then a 60" will have issues as there is not enough clearance to raise the deck off of the ground without hitting the tires. For the rest of the 790/3005 tire size options it should not be a problem but that does indicate a difference between the 2 machine decks.
2019 Kubota F3990 72 in. Commercial Mower (A50324)
2019 Kubota F3990...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2019 KENWORTH T680...
2016 PETERBILT 587 (A50854)
2016 PETERBILT 587...
