JD 4100 Front Loader Sluggish
   / JD 4100 Front Loader Sluggish #1
Angy
John Deere 4100
My JD 4100 front end loader is sluggish
   / JD 4100 Front Loader Sluggish #2
Is your hydraulic fluid at the proper level? What's the position of your three point control? If it is in the full up position that can slow the front loader. If that is the cause there's a simple adjustment to fix it. After these it's possibly a filter, screen, or suction line problem.
   / JD 4100 Front Loader Sluggish #3
That model has a cleanable filter in the sump. Take it out and scrub it up. That may or may not be the fix, but it is where you have to start. While there, take a look for an old weathered hose that may be causing a air suction leak for oil moving between the sump up to the hydraulic pump.
   / JD 4100 Front Loader Sluggish #4
Could be wrong viscosity hydraulic fluid. MUST be LO-VIS. Don't ever use generic hydraulic fluid in the JD or Kubota tractors.
   / JD 4100 Front Loader Sluggish #5
Angy
Did the loader suddenly start moving sluggish or has it slowly been getting worse?
If suddenly does it sound like the tractor is straining when trying operate the loader?
JOHN DEERE 9650 COMBINE (A51243)
JOHN DEERE 9650...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A51219)
2016 INTERNATIONAL...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
1261 (A50490)
1261 (A50490)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2015 FREIGHTLINER CA125SLP SLEEPER (A51219)
2015 FREIGHTLINER...
