JD 4100, 410 Loader Capacity, Fork Weight Recommendation
   / JD 4100, 410 Loader Capacity, Fork Weight Recommendation #1
redstatedog
Can someone please provide the lifting capacity of my JD 4100, 410 loader?
Any suggestions as to the proper fork attachment for my equipment? I don't want to over-purchase an attachment that is too heavy and therefore limit my lifting capacity. I was thinking I would purchase the lightest set of forks that maximize my lifting capacity. Any thoughts or suggestions would be appreciated. Thanks in advance.
   / JD 4100, 410 Loader Capacity, Fork Weight Recommendation #2
You can load it heaping full of gravel. I hauled about 22 tons of gravel with it.
Think it's somewhere between 1,000 and 1,200 #. Do a search. Think someone reported the official weight limit in the past. My manual did not have a value in it. Says to put 770 # of ballast. Most I've used is my 400 # LX4.
Ralph
   / JD 4100, 410 Loader Capacity, Fork Weight Recommendation #3
I thought it was 800-900 pounds, but can't remember for sure...
I built my own fork setup that fits the JD quick-attach setup, as did quite a few other's here if you do some searching. Your JD dealer sells the Frontier brand that will fit for about $600-$700.
Do you have a welder and basic fabrication skills?
Thanks for the responses.
Welding is not an option, sad to say. I was impressed by the set you made Kennyd, however I do not have that skill. Therefore, I will need to purchase my fork attachment. A potential concern I have about purchasing the Deere/Frontier brand is that I read in a previous thread that those brand forks may be overkill and very heavy for my 4100 (more appropriate for larger model tractors) resulting in a signifcant loss of lifting capability. As a result, others have recommended lighter weight forks to retain more lifting capability. There in lies my dilemma. I am trying to balance adequate fork strength while maximizing lifting capability. I just assume purchase the Deere forks (even if a bit more $) if they wouldn't signficantly reduce my lifting capacity.
   / JD 4100, 410 Loader Capacity, Fork Weight Recommendation #5
I understand your concern about the weight of the forks, but finding a light duty set that will also connect to the JD QA setup will be the problem. I believe the Frontier forks weight about 250lbs or so leaving you with 600-700lbs of lifting capacity.
Where are you located? If you want to make a road trip to MD we will build you a set:D
   / JD 4100, 410 Loader Capacity, Fork Weight Recommendation #6
Horst welding makes (at least they did) a lighter set. I compared it to the Deere branded model a few years back. The Horst tines were longer (I think)and were of box construction. Plus a few $$ cheaper. I went home with the Horst. Concerns I had about the box beam forks were dispelled; I moved bunchs of pallets, wood/tree trunks, brush (long forks work great on brush piles) and picked up a few heavy shop tools (air comp & metal lathe) to no ill effect. Have put enough of a load on them to stall the FEL (18 foot dock) without bending the forks. BTW, I do like the adjustability (width). Good luck.
As I am located in Michigan, MD is a bit of a hike although I appreciate the suggestion KennyD.
I think I will consider the Horst brand as suggested, however, unless they will ship direct, I may be out of luck as they do not appear to have a licensed dealer near me.
2016 Ford Explorer AWD SUV (A55758)
2016 Ford Explorer...
2011 FREIGHTLINER CASCADIA (INOPERABLE) (A55745)
2011 FREIGHTLINER...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
2004 Jeep Liberty Limited SUV (A54815)
2004 Jeep Liberty...
2003 Pierce Spartan Pumper Fire Truck (A51692)
2003 Pierce...
2022 John Deere 3033R Compact Tractor (RIDE AND DRIVE) (A50775)
2022 John Deere...
