JD 410 Backhoe loader boom respond very slowly when warming
   / JD 410 Backhoe loader boom respond very slowly when warming #1
jkk04
PLYMOUTH CA
John Deere 410 backhoe, MF 30 industrial tractor, IH TD-14 dozer, New Holland TZ24DA
Hello, Members.
I have JD 410 backhoe has some issue that loader boom respond very slowly after 20-30 minute operating the tractor.
I am sure It was not hydraulic pump problem because backhoe boom and bucket cylinders works fine even after some time operation.
So guessing the boom cylinders or control valve are leaking internally.(I don't see any leaking out side.)
Any suggestions or advice will be appreciated.
Jkk
   / JD 410 Backhoe loader boom respond very slowly when warming #2
Possible boom cylinder leaking internally.
   / JD 410 Backhoe loader boom respond very slowly when warming #3
Hello, Members.
Jkk
If you lift the front of the machine off the ground using the loader, will it hold in that position, or leak down?
Thank you for replying
Yes.
it is leak down immediately that meaning it needs to replace the both cylinders seals.
If so, is it hard to replace the seals myself?
I see the aftermarket seals(part no: AR105402) sold for $ 25 on ebay or less but The oem seal is more than $ 125.
what do you think. I am using the backhoe for my property once a while.
Thank you again
Jkk
   / JD 410 Backhoe loader boom respond very slowly when warming #5
If 1 seal is leaking it will not hold. When the machine is cold start it up hold the loader control leaver on curl for 1/2 min. then feel the top of each cylinder the one that is warmest will be the one to replace the seal. I'd go with a $25 seal kit there's not much to them.
Hi, Billrog.
Thank you for your rreply.
I think right boom cylinder is little warmer than left. But it was hard to check.
Will update
Jkk
   / JD 410 Backhoe loader boom respond very slowly when warming #7
I very recently had a tractor bucket that wouldn't hold & having read that method here or some place thought it would be worth a try . The temp. was was only slightly warmer but the result was I took the right cylinder apart to fix. 20170621_123607.jpg
Finally I have time and trying to remove cylinder rod. But it seem to me very hard to remove the snip ring.
Did any member have experience to remove it and sharing the expert? will be appreciated.
John Deere 7000 8 R Planter (A50515)
John Deere 7000 8...
Komatsu WA250-5L Wheel Loader (A52384)
Komatsu WA250-5L...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
2017 Dodge Caravan Van (A50324)
2017 Dodge Caravan...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
2009 Chevrolet TrailBlazer Multipurpose Vehicle (A51694)
2009 Chevrolet...
