JD 4030 pto issue
   / JD 4030 pto issue #1
smead
IH 574
hey folks - looking at a 4030 that was along side the road for sale (~6000 hrs). They want $9000 with a monster JD 115 grading blade. I think I could maybe buy it for $7500. Seems to run really well except for that convoluted syncro shift pattern that I had never dealt with before BUT the PTO lever will not stay in the engaged position. The PTO turns when you hold the lever up but will not stay there. Any clues if this is somethingmajor or minor. Doe this sound like a fair deal or not? - steve
   / JD 4030 pto issue #2
That problem can often be fixed from the outside without a lot of expense, but sometimes will require a split depending on the actual cause of the problem. The tractor is probably worth closer to $9K than $7500 if it has decent rear rubber and no other problems.
   / JD 4030 pto issue #3
30-55 series rowcrop tractors with syncro & quad range trans have a history of an arm bending(part # R67981) that a engagement piston hydraulically pushes against to hold pto lever in the "on" position. Can be repaired without splitting simply by R&R of clutch control valve on LH side of tractor. Syncro-range shift pattern isn't bad after one shifts it a few 100 times. All shifts except range changes are synchronized.
2010 FREIGHTLINER CASCADIA TANDEM AXLE MID ROOF SLEEPER (A54313)
2010 FREIGHTLINER...
2018 HMDE TL & 2014 VERMEER (A53421)
2018 HMDE TL &...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
STORAGE FEES (A54607)
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
