JD 400CX FEL Question
   / JD 400CX FEL Question #1
ayesinstructor
SW Michigan
JD 4520
Hi All,
Have a 4520 w/400CX FEL on order. This may be a foolish question, but can anyone advise if there is a "float" position for the FEL and if there is a required procedure to activate? When pushing snow, it would be nice to have loader follow driveway contours.
Thanks,
ayesinstructor
   / JD 400CX FEL Question #2
I'm 100% sure there is. I believe it's actually a function on the hydraulic valve itself as opposed to the loader. On the 4320 you just push the scv (loader control) lever all the way forward (bucket down movement) into a "detent" position and it's in float. The third scv also has a float position I believe. Our 4320 with 400X loader certainly floats and it is handy. You may find bucket is less than an optimal tool for snow though!
   / JD 400CX FEL Question #3
The 400x has it. Just raise your bucket a couple of feet off the ground and "quickly" push the boom down and then let off. It should "float" down till the bucket hit the ground. It takes a little getting used to doing it. But, it helps to start with the bucket in the air.
   / JD 400CX FEL Question #4
What they said!
They ALL have it, it's in the valve that comes with the tractor-doesn't matter which loader you get.
   / JD 400CX FEL Question #5
To get a better "feel" for the detent position I practiced a few times with the tractor turned off.
Thanks to everyone for their input and suggestions. Its really great to have a site for information on compact utility tractors. As soon as I take delivery (hopefully soon) I will experiment putting this in "float" mode.
ayesinstructor
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2010 International 4400 National Crane 300C Crane Truck (A50323)
2010 International...
2019 PJ 25 T/A GOOSENECK TRAILER (A50854)
2019 PJ 25 T/A...
2021 POLARIS RANGER 4x4 UTV (A51222)
2021 POLARIS...
MAXUM 1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM 1000 TRIPLEX...
