JD 4000 series vs 5000
   / JD 4000 series vs 5000 #1
deere755
Platinum Member
central Illinois near Lake Shelbyville
Case 2090 Massey Ferguson 4233 John Deere 4700
I have been doing a little looking at new tractors and I don't understand why a basic 4520 or a 4320 is 9 to 10 thousand more then a 5045 or a 5055. Are the 5000 series tractors not built as well as the 4000 series? I get to looking and the 5055 seems like a lot of tractor for the money. It would serve my needs as well as a 4000 series if not better. I realize the frame is bigger on the 5000 but that wouldn't be an issue for me. What am I missing?
   / JD 4000 series vs 5000 #2
I think the 4x20 series is a "premium" line tractor with bells and whistles like ehydro or the power reverser tranny and other "comfort" features. The 5k series are workhorses without a doubt. I had a 5203 a few years back and it was unstopable. I considered a 5101 E Limited recently when I bought a 4720 cab. It was just too large for some of my applications. I would go 5k series for most farm apps...
   / JD 4000 series vs 5000 #3
I finally signed the Purchase Order for a new, cabbed 5075M this past week. I went back and forth for months on the question of 4000 vs 5000 tractors.
Really came down to the jobs at hand....
I want to run a small round baler (4'x5') and 10-bale accumulator and grapple for my small square baler.
I think the 4520-4720 have the Hp but I'm cautious about the long-term reliability of using those machines for more directed Ag work.
So, I spent a little more $$ up front and hopefully avoided having to spent alot later on to rebuild a tractor not well suited to the work required.
AKfish
   / JD 4000 series vs 5000 #4
It's all the bells and whistles that make the 4000 series more expensive. Also, the intended market is a bit different and that market has a different price point. The 5000 series are a utility tractor whereas the 4000 series are a compact utility tractor (although large ones.)
My father just got a 5045E after looking at the larger 4000 series tractors. He was upgrading from a JD 4400 HST that was nothing but trouble for the last 1000hrs or so. Since it will be used strictly for farm work the 5045E ended up being a much better choice for less money. The only drawback was they wanted a hydrostatic trans, but it turns out the sync-shuttle on the 5045 works so smooth that it isn't much of an issue. The 5000 series are surprisingly heavily built for their size, all the components are made overseas (India and China, loader in Mexico) but these particular tractors have been out for quite a few years now with little trouble. I've put about 30hrs on it in the last couple weeks and I really like it, a very smooth operating, solid tractor.
I don't have much knowledge of the new 4000-series, but I think they are based on the older 4500-4700 chassis tractors. There is just too much electronics on the new 4000 series for my liking.
   / JD 4000 series vs 5000 #5
The difference is features and upgrades.
An example would be the 5065E base is 19,600
5065M base is 39,000
about $20,000 difference between an E and an M.
   / JD 4000 series vs 5000 #6
What are you planning to do with the tractor?
Are you comparing the most expensive 4000 machines with the least expensive 5000 machines?
You need to evaluate the machines as much as possible with similar configurations with the type of work in mind - IMO.
A "tricked out" cab 4520 vs a 5055E is not a real world apples vs apples - comparison.
AKfish
   / JD 4000 series vs 5000 #7
AKfish
I looked one over at the dealer Thursday closely after talking to you, I think you will be well pleased with it.:thumbsup::thumbsup:
   / JD 4000 series vs 5000 #8
If you are looking at the 4x20 series and ever think a CAB might be in your future then check the 5083E Limited. Prediscount pricing (depending on options) is in the ball park of 4320 and quite probably less than 4520 / 4720.
Depending on FEL options lift capacity is significantly greater than the 400CX versions.
   / JD 4000 series vs 5000 #9
I agree on looking at a 5083 is you are seriously considering a cab 4520 or 4720. That is what I intend to do in the future, and I currently have an open station 4320. I think they costs so much more than the 5000 series primarily due to the power reverser transmission and the fact that all gears within a range are synchronized.
   / JD 4000 series vs 5000 #10
The 5083E is alot of tractor for the money!! Seriously considered one.
Some of the differences between the cab 83E and the cab M series is air seat, wet clutch PTO, 16 or 32 speed PowerReverser vs 12 speed and more hydraulic options and higher flow rate.
The rear axles and axle housing and 3pt configuration on the M series is significantly heavier duty, too. About 750lbs worth!
AKfish
2015 KENWORTH T680 (A45046)
2015 KENWORTH T680...
2005 INTERNATIONAL 4400 BUCKET TRUCK (A45046)
2005 INTERNATIONAL...
2014 UTILITY 53X102 DRY VAN TRAILER (A43004)
2014 UTILITY...
JCB MAST FORKLIFT (A45046)
JCB MAST FORKLIFT...
2007 Ford Mustang (A44501)
2007 Ford Mustang...
2003 VIKING TRAILER CEMENT MIXING TRAILER (A45333)
2003 VIKING...
