JD 3X20 Differential lock pedal
   / JD 3X20 Differential lock pedal #1
Dan Hunter
Platinum Member
Enid, OK
2012 John Deere 3720 eHydro
I'm I the only person that finds the length and position of the diff lock pedal inconvenient. Yeah, I have the seat forward and that complicates access but when I'm trying to use it I always think of this:
   / JD 3X20 Differential lock pedal #2
Hmm, don't think I've ever used mine other than when I first got it to see if it worked, usually have mine in 4x4. Seemed like it was a bit awkward to get it to engage.
Exactly. I use it EVERY time I back onto the trailer and any loose slopes.
   / JD 3X20 Differential lock pedal #4
I find it awkward too.
I use my 3320 to mow my lawn and use the diff lock all the time in one particular place where I have to turn 90 degrees, go up a fairly short hill (30 feet?) and then turn again. I always get one rear wheel spinning when making that first turn, so hitting the diff lock gets it going just right. If I use MFWD there I'll rip up too much lawn in the tight turn(s).
   / JD 3X20 Differential lock pedal #5
Very awkward. Still, better than not having the option at all.
   / JD 3X20 Differential lock pedal #6
not fond of it in my cab either. terrible location and terrible engagement. I have only used it to test it myself and it actually does work thank god. luckily for me, I haven't ran into a situation where I have had to actually use it. my 4 wheel drive works good enough where I don't need "3"wheels turning. actually hurts my knee when trying to hold down until it locks in
   / JD 3X20 Differential lock pedal #7
Interesting, I don't have any problem with mine at all. Less than optimal traction with R4 tires means I use mine regularly. That said, the tractor must either stationary - or traveling in a straight line - when engaging/disengaging diff lock. Otherwise the disparate rotational speeds of the rear wheels will make engagement/disengagement difficult or impossible. Internal damage is not out of the question either. Plus it helps that I'm a six footer, so the seat is always all the way back to the stops.
//greg//
   / JD 3X20 Differential lock pedal #8
Another one that hates it. In the almost 6 years of owning this tractor, I probably have only used it 10-15 times and that was when it was really sloppy out, and it is just a pain in the butt to use. I know it is supposed to remain engaged when there is constant wheel slippage, but when you have a lot of grab/loss/grab/loss conditions, it sucks to have to use your heel to hold it down. Like was said though, I am glad to have it, just wish it was more convenient to use it.
Dry Gel Hydration Unit (A53843)
Dry Gel Hydration...
2013 SHOP BUILT FLARE STACK (A53843)
2013 SHOP BUILT...
2006 TerraGator 8104 (A53473)
2006 TerraGator...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
ROLL OFF BOX (A53843)
