JD 375 Hay Baler
   / JD 375 Hay Baler #1
gulfofmexico
I have a new (used) JD 375 hay baler. Will my kubota 40 hp (pto) tractor handle this baler? I bale about 40 acres of bermuda on level ground.
   / JD 375 Hay Baler #2
It should, assuming you are not pulling a big wagon load of bales too. Can you let them drop on the field and pick thm up in a seperate operation? Or let the customer pick them up directly, if selling. Nicer shaped bales if they drop, compared to having gone thru a thrower. Also, if the 375 has a thrower, it takes power. Disconnect it.
   / JD 375 Hay Baler #3
It might.....the small 5X4 bales don't usually take as much HP, but I think you'd be pushing that little tractor pretty much to the max. You'll likely have to make smaller bales. 40 hp is the minimum for a Vermeer 5410 and it will give a 40hp tractor a good workout.
EV-N-Spread Seeder (A47477)
EV-N-Spread Seeder...
16ft T/A Flatbed Trailer (A55788)
16ft T/A Flatbed...
2022 Kobelco SK85LS Mini Excavator (A54865)
2022 Kobelco...
2017 KUBOTA SSV65 SKID STEER (A52706)
2017 KUBOTA SSV65...
Chicken Weathervane (A53316)
Chicken...
