JD 3720 vs. Kub 4240
/ JD 3720 vs. Kub 4240 #2
Rich P said:
Any comments appreciated.
Ahh, one is green and one is orange?:rolleyes:
Very true. Anything else??? They both have tires (actually I'm getting turf tires)
/ JD 3720 vs. Kub 4240 #4
The JD has the brake pedals on the correct (left) side so you can use them for brake steering.
/ JD 3720 vs. Kub 4240 #6
But wait to see what Messick says cuz he's the expert on everything in the JD section....Even tho' he's a competitor.
/ JD 3720 vs. Kub 4240 #7
Hey somebody has to take up Cowboydoc's and Rockyridge's slack.
The 3720 is a great tractor. I'm sure the Kubota is a good machine too.
Make sure you check out the dealer's really well for service, parts, etc.
JD has an online parts dept that you can look up parts, exploded views, prices, availability and even order if you want to. No one comes close to that.
Dealers are both equidistant and both are great. I've run Kubota i the past and all was well with the machine. The thing about the JD that scares me a bit is dealing with a turbo in the event of problems and does the JD have a differential lock?
/ JD 3720 vs. Kub 4240 #9
Rich,
The JD's do indeed have a diff lock, and turbochargers are a very simple and proven design that boost performance and efficiency.
You need to drive each one, and then ask more specific questions, your "any comments" is just to broad.
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
1996 International Water Truck with a Caterpillar Engine (A61307)
1996 International...
KBH Tender Trailer (A61307)
KBH Tender Trailer...
2013 Ford F-250 Pickup Truck (A55973)
2013 Ford F-250...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
