JD 3720 Load match speed match
   / JD 3720 Load match speed match #1
NFDeere
JD3720 and JD4300
I recently purchased a 2012 JD3720. How do a operate the load match and speed match functions? It doesnt have a seperate switch for load or speed match. The display and turn switches dont seem to work.
   / JD 3720 Load match speed match #2
Welcome to TBN
Do you have the operators' manual?
I do, it says to use the display button and the turn button but the turn button doesnt seem to do anything other than turn signal.
   / JD 3720 Load match speed match #4
Contact your local dealer...if you bought the 3720 from a dealer, they should be able to help...possibility the load match may be "broken"...
Even if you bought it from a private party, the dealer's techs might be able to give you some guidance
   / JD 3720 Load match speed match #5
You have to have the automotive cruise option with three switches.
   / JD 3720 Load match speed match #6
You can still purchase it part #LVB25866
Thank you for your help!
White Metal Roof Panels (A55758)
White Metal Roof...
2017 INTERNATIONAL LF687 DAYCAB (A58214)
2017 INTERNATIONAL...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
GMC 2500HD 4wd Service Truck (A56436)
GMC 2500HD 4wd...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58216)
FOUR WAY BLADE...
