JD 3520 mid PTO option and 62D compatible?
   / JD 3520 mid PTO option and 62D compatible? #1
scott@ipdusa.com
Howdy-
My first post. Looking at a used 3520 and wondering if the mid PTO option can be installed as an upgrade or does it have to be installed as a factory option?
JD wesbite says it's a $400 option, but does not indicate if it can be added at a later date.
Also, wondering if the 62D mid mower can be used on the 3250.
Thanks!
   / JD 3520 mid PTO option and 62D compatible? #2
The mid-PTO can indeed be field installed, about a 3-4 hour job or so...not sure about the 62D...you will have to go to the "build your own" section on the JD site and see what it allows you to add.
   / JD 3520 mid PTO option and 62D compatible? #3
Quick question why a 62D?
Main reason is that there is one local here on Craigslist new on a pallet for $1700! I took th eadvice of the fellow above and went through the JD configurator and the 62D does not appear to be an option for the 3520.
There's also a Loftness 7' flail mower listed fo $895, which looks like it might be a good option too.
   / JD 3520 mid PTO option and 62D compatible? #5
Remember that you'll need the 3x20-series mounting frame for the 62D as well, I doubt the 2x20 series would be a good match.
   / JD 3520 mid PTO option and 62D compatible? #6
i was gonna be quite surprised if the 62D would be compatible with the 3x30 series.
I would say it is, depending on the condition, a $5k mower for $.9k - Sweet!
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
Yamaha 4-Wheeler (A50121)
Yamaha 4-Wheeler...
Cub Cadet Z-Force Zero Turn Mower (A50121)
Cub Cadet Z-Force...
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
1999 John Deere 7810 (A50120)
1999 John Deere...
2015 John Deere 8245R (A50120)
2015 John Deere...
