tugboat-2
Platinum Member
- Joined
- Jan 12, 2007
- Messages
- 576
- Location
- ERIN, Ontario, Canada
- Tractor
- Many over the years, + '05 JD-4410 TLB, but quite proud of my big green "Rolls": AKA: 2006 JD-3520 Cab, HST, Tunes & 2-way tiltmeter, Cobra communications and 6" (x2) rear wheel spacers for a lot less pucker-factor!!
My 2006-JD-3520-Cab,... just racked 900 hours and on its third,..(3rd) MFWD "driveshaft". The shaft that comes forward from the transmission to the front differential.
Its splined-end meets the splined shaft coming out the back of the front diff. The two slide into a short,(3") common, internally splined "sleeve",..(with a pin through the centre).
Load-Match and 4WD engaged constantly unless in transport or mowing. I dig and move lots of earth, "working" my machine, but never purposely abuse it.
First shaft went (last year) suddenly. The next gave a quick warning. Driving down a steep, 20ft hill, filling my bucket and "backing" up the hill all afternoon,.. no problem.
Went down scooped a 1/2 load for front ballast, scraped up a pile with rear blade,.. filled the bucket and crawling up frontwards (low gear @2500 RPM) felt a quick slip'n'grab, slip'n'grab and detected a faint clicking as I came over the top. Dumped my bucket and parked.
Slid under checking "everything" for "anything", shafts, linkage, pins etc. Removed dash panel to check "travel" and freeplay in the MFWD "lever". The "Brail-method" confirmed lever engagement of detent spring-balls that "hold" it in gear,...yet there was NO drive at wheels! Checked oil levels and anything else I could think of, All OK. The driveshaft "felt" tight.
Testing,..(smooth and quiet) in 2 wheel, but 4WD,..."Nothing"!! So dropped grader blade and bucket, connected RFM and mowed a couple hours without incident.
Next day, drove 'er the quarter mile to my dealer. The shaft and sleeve splines, were rounded off, warn and chewed like you'd expect from "softer" metal.
New shaft and sleeve wouldn't be so bad,..but the "other" shaftspline was just as bad,....EXCEPT:..it's the back end of the front "pinion" gear (one solid, short shaft) which means dropping the front axle, splitting the case, pulling out the carrier, (Crown and pinion, side gears and bearings etc), and replacing the pinion,...which is a pre-set "package" with bearings etc complete!!!
They suggested the alternative: "welding" everything solid, to save a major expense. But agreed the possibility of "heat" damage through the short pinion shaft to seals and bearings was not a good choice. (good idea on an old beat up tractor,...but WHOA!! This Baby is still brand new to me,..still shines up to a Beauty!!!) So I authorized a full and proper job. This is precision work in a clean shop with the right tools and not for my dusty, gravel floored drive-shed. (Note: no paper gaskets,..just metal to metal with liquid sealant spread thin with an ink roller and torqued! A sterile operation for the OR!!)
Meanwhile I have my tractor back, up and running,...but am walking on eggshells,..hesitant to go back to anything heavy. Perhaps having a brand new machine made me a tad "over" confident??
Well OK, now that you've endured another long winded "tug-tail",...."IF" you're still with me,......have any of you experienced anything similar?? AGAIN: This is an (Xmas) 2006 JD-3520-Cab,...(my beautiful Rolls! Cab still has that "new-car" smell,..ha,ha!)
I'd appreciate your thoughts...?
. . tug
. . tug
