Jd 3520 Fuel Milage
   / Jd 3520 Fuel Milage #1
Beechboy
Greenwood BC Canada
2010 JD 3520,2008 JD LA 175, 1946 Ford 2N
Morning Folks
Curious how many hours people are getting on a tank of diesel fuel on their 3520 tractors.
I seem to be going thru a tank in about 3 hours of moderate use , any suggestions??
   / Jd 3520 Fuel Milage #2
Morning Folks
Wow, that seems terrible, you didn't say what type of work you are doing which would certainly impact your fuel consumption. My JD 3720 which has slightly more HP than yours easily makes 10+ hours on a tank. That is running a 6' RC at 540 PTO RPM in A (low) and half the time in 4WD.
Yea I figured it was pretty lousy, I'm just using the Fel and the 485 backhoe at around 2500 Rpm.
As usual the dealers response was "Oh that's normal" it's a 2010 model. Is there any additive that can be used to clean the fuel system??
By the way, I really baby this machine, had it since new, 1230hrs total time on it!!
   / Jd 3520 Fuel Milage #5
I just looked at the specs and do you have a cab (11.8 gallons) or open station (13.5 gallons)? Even with the smaller tank you're burning almost 4GPH. Does your fuel tank hold the correct gallons when you fill it up? I have never actually tracked my fuel consumption but I do know it takes me about 5 hours to mow my place and I can get two mows from a full tank 13.5 gallons. Although just looking at the numbers burning 1.3 gallons per hour seems a little optimistic to me. Hopefully someone else will chime in. I treat my diesel with Power Service only because I store 100 gallons.
Are we talking US or Imperial gallons here?
It's an open station Canadian model, just filled it to the cap to see if the warmer weather makes any difference.
   / Jd 3520 Fuel Milage #7
Air filter clogged ?
Great idea, pretty sure I replaced both prior to winter, however it gets so busy around here I may have overlooked it or put it on the todo list. Will check my records and the filters!!
Thanks for the reminder!!
Well just filled her up to the cap, managed to get 17 hrs on a full tank, maybe someone has been syphoning some fuel . Maybe I am just working to hard lol Time Flies when you're having Fun!!
BY VALLEY INDUSTRIES 60 R22 823 LOT IDENTIFIER 221 (A53084)
BY VALLEY...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
UNUSED AGT SA-FT HYD PALLET FORKS (A51248)
UNUSED AGT SA-FT...
Year: 2014 Make: Kia Model: Sorento Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 129,485 Pla... (A51694)
Year: 2014 Make...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
