JD-345 Electric problem
   / JD-345 Electric problem #1
leftybob
Bronze Member
Barnhart, Missouri
Ford-1100- New Holland 1720 - JD-345- JD-425- Cub Cadet- 1863
I have a 95- JD 345 all electric goes dead. sometimes if I wiggle the connectors at the circut board it will make connection. Is there anyway to check the board. They are not in a good place as they get dirty. I cleaned it once and reconected all plugs and fuses and it worked for about 3 mo. Any idea's?
   / JD-345 Electric problem #2
Without a complete testing of the electrical system and the circuit board it's hard to say, but I can tell you that it would not be the first case of a bad circuit board. IMHO, you're going to have to straight-wire around the board (use an applicable fuse) and test each component or at least a couple. Or test for continuity through the board on each circuit - just one leg/wire at a time - not across them. Lastly, check all grounds and make sure they are good. This should give you a pretty good idea of whether it is the board or not.
Thanks for your reply. It was a ground problem from the battery to engine.
2013 Road King 30ft T/A Boat Trailer (A51694)
2013 Road King...
2018 CHEVROLET SILVERADO 2500HD (A53843)
2018 CHEVROLET...
2014 INTERNATIONAL 4300 INSULATED COLD BOX TRUCK (A54607)
2014 INTERNATIONAL...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
2010 DODGE RAM 2500 FLATBED TRUCK (A51247)
2010 DODGE RAM...
