JD 335 Traction Drive Belt Spring
   / JD 335 Traction Drive Belt Spring #1
rlhatejd
GX335
How have you guys been able to get the tension spring off the JD 335 lawn tractor? It's about 18" lg., 1 1/2" dia. with about 5/16" wire dia. This is a very strong spring & there's no room under the tractor to use a tool to pry either end of the spring off its anchor point. The spring must be unfastened at one end, or you can NOT remove a bad traction belt for replacement. HELP ~ anyone? Many thanks.
   / JD 335 Traction Drive Belt Spring #2
Some of those springs are a booger to work with. I sometimes use a brake tool or something with a strong hook on the end.
You have to get some leverage somehow being careful to not lose a finger.
You can cut the belt in some places, but getting the spring back on may still be problem.
MAHINDRA 1635 TRACTOR (A54756)
MAHINDRA 1635...
2019 HINO 195 LCF BOX TRUCK (A54607)
2019 HINO 195 LCF...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2016 CATERPILLAR 306E EXCAVATOR (A52705)
2016 CATERPILLAR...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
