JD 335 Traction Drive Belt Spring
   / JD 335 Traction Drive Belt Spring #1
rlhatejd
GX335
How have you guys been able to get the tension spring off the JD 335 lawn tractor? It's about 18" lg., 1 1/2" dia. with about 5/16" wire dia. This is a very strong spring & there's no room under the tractor to use a tool to pry either end of the spring off its anchor point. The spring must be unfastened at one end, or you can NOT remove a bad traction belt for replacement. HELP ~ anyone? Many thanks.
   / JD 335 Traction Drive Belt Spring #2
Some of those springs are a booger to work with. I sometimes use a brake tool or something with a strong hook on the end.
You have to get some leverage somehow being careful to not lose a finger.
You can cut the belt in some places, but getting the spring back on may still be problem.
2003 CATERPILLAR 420D IT BACKHOE (A52705)
2003 CATERPILLAR...
RHINO 160 - 5' ROTARY MOWER, 3PT (A54756)
RHINO 160 - 5'...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
2011 New Holland B95B Cab MFWD Loader Backhoe (A55218)
2011 New Holland...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
2013 VOLVO VNL64T TANDEM AXLE MID ROOF SLEEPER (A54313)
2013 VOLVO VNL64T...
