JD 333G can joysticks usage be reversed?
   / JD 333G can joysticks usage be reversed? #1
cascade202
John Deere 333G
The loader came with the lefthand joystick controlling loader movement and the righthand joystick controlling the bucket. Can this be reversed where the righthand controls movement and the lefthand controls the bucket?
   / JD 333G can joysticks usage be reversed? #2
I’d say if you can switch the hydraulic lines around yes. For example on my J.D. 2025r it has a quick connect loader and the hoses are color coded. If I change the way they are hooked up the joystick functions will change.
   / JD 333G can joysticks usage be reversed? #3
I believe 333G is a skid steer. Not sure you swap joystick functions side to side. Does it have any option for European control Vs american?
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
EZ-GO golf cart (A56859)
EZ-GO golf cart...
HAY SPEAR W/ JOHN DEERE LOADER MOUNT (A58374)
HAY SPEAR W/ JOHN...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Berky Weedo Amphi King 6450 Amphibious Workboat (A56857)
2019 Berky Weedo...
JOHN DEERE 6500 HI-CYCLE SPRAYER (A52708)
JOHN DEERE 6500...
