JD 3320 suddenly will not move. Throws an error code 14. Solonoid coil insufficient. Bought a new coil but can’t find where the solonoid is located!
   / JD 3320 suddenly will not move. Throws an error code 14. Solonoid coil insufficient. Bought a new coil but can’t find where the solonoid is located! #11
got a bad feeling that may be inside the transmission
   / JD 3320 suddenly will not move. Throws an error code 14. Solonoid coil insufficient. Bought a new coil but can’t find where the solonoid is located! #12
This guy says he found something under the fuel tank in a narrow hole on the bell housing.
I went to the JohnDeere dealer and spoke to a helpful parts manager who printed off numerous tech pages for me. The reason I couldn’t find the solenoid is because it is in the center case of the transmission. I will write more after I continue working with the tech sheets.
The solonoid in question is not for the starter. The engine runs fine. The solenoid controlling hydraulic fluid flow to the hydrostatic transmission can not be seen located either in the center case of the transmission housing or above it .
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
13042tx (A55973)
13042tx (A55973)
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
Kubota M4700 (A60462)
Deere 331G (A53317)
Deere 331G (A53317)
