Snowblower JD 3320 MMM Rear Hydraulics to Rotate Rear Snowblower Chute
   / JD 3320 MMM Rear Hydraulics to Rotate Rear Snowblower Chute #1
KennK
NE Wisconsin
John Deere 3320
I have a John Deere 3320 purchased in 2006 with a mid mount mower (now removed) and the two rear hydraulic connectors that I assume drive the mower lift/lower.
I'm thinking about buying a Woodmaxx snowblower, and I'm wondering if I can disconnect & cap the rear hydraulic hoses that I think lift/lower the mid mount mower (the MMM is not on the tractor) and connect/use the rear hydraulic ports to rotate the snowblower's output chute.
The MMM lifts/lowers using a lever on the right side of the seat (next to the rear rocker arm lift/lower), so I assume it would be able to rotate the chute by pushing/pulling that same lever.
Any advice/insight you can give would be very helpful.
   / JD 3320 MMM Rear Hydraulics to Rotate Rear Snowblower Chute #2
Yes, I would think you could use your rear remote for your snowblower.
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
Massey Ferguson 65 Loader Tractor (A50514)
Massey Ferguson 65...
2011 Ford Edge SEL SUV (A50324)
2011 Ford Edge SEL...
2019 FORD F-150 (A50854)
2019 FORD F-150...
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
