JD 332: shorted switch on body, no electrical panel.
   / JD 332: shorted switch on body, no electrical panel. #1
manfrom58
gatineau
jd 332
Hi all, happened on my JD 332 lawn tractor , I was removing the start switch and shorted it by mistake on the body, now the electical panel is dead. I check the fuse s , all ok. Any ideasノ
   / JD 332: shorted switch on body, no electrical panel. #2
I would check the ground on the switch and then the frame. If that checks out then I would start tracing the positive from the battery terminal back through the circuit until you find where it stops. My 332 had a very weak grounding strap that connected the negative to the frame that eventually lost conductivity even though it looked connected. I replaced it with a battery cable and it worked fine for years. I have new problems now and I suspect the time delay module is the culprit as it needs all circuits to check out before allowing 12 volts through the switch. If yours traces back to the same module, then I would suspect that as well. It is a small black box below the ignition switch mounted on the bottom of the dash tower. I don't think you can fix it, just replace it. Hope it helps.
   / JD 332: shorted switch on body, no electrical panel. #3
You may have burned out the contact in the ignition switch.
You may also have a fusible link that is blown, a fusible link will look like a black rubber cigar in the wire,
very small, if it's blown, there will be a bulge in it, if you have one, that is.
   / JD 332: shorted switch on body, no electrical panel. #4
Not to be a smart ***** but that's why we disconnect the battery when working on electrical systems. BTDT.
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
2012 MACK GU713 DUMP TRUCK (A50459)
2012 MACK GU713...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
Master MGH8500IE 8,500-Watt Generator - Electric Start, 18HP Honda Engine (A51039)
Master MGH8500IE...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
