JD 325 low rpms when pto ingaged
   / JD 325 low rpms when pto ingaged #1
Plaz
Gretna, Ne.
JD 325 garden tractor
My 325 runs great until i engage my pto. Then it bogs down and wont go to full RPMS?
Anyone have a idea. It will go to full RPMS if I try and try. but it still will do it when the pto is diengaged.
   / JD 325 low rpms when pto ingaged #2
The first thing I'd check is for old fuel or a dirty fuel filter. I've had similar issues when the engine would run fine with no load, but didn't want to run under load. Fortunately, it's an easy fix.
GGB
I'll give it a try. Thanks
2004 Caterpillar 345B Hydraulic Excavator (A53421)
2004 Caterpillar...
2021 CATERPILLAR CB2.7 DBL DRUM TANDEM ROLLER (A52705)
2021 CATERPILLAR...
UNUSED LANDHONOR RTH-13-2000G HYD TREE GRAPPLE (A54757)
UNUSED LANDHONOR...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
