JD 317 will only run in the start position
   / JD 317 will only run in the start position #1
Denny3223
shirleysburg , pa
john deere 317
This is a new issue. My 317 will only run in the start position.When i release the key it shuts down. This started only after I started mowing and the pto was engaged, the engine would shut down. Seem that it was getting hot. This is a barn find and ran fine plowing this past winter after new fuel pump and being cleaned up. Would bad mower deck bearings cause too much resistance causing overheat? Any Ideas? Possible Fuse or rectifier?
   / JD 317 will only run in the start position #2
I am wondering if there might be a resistor between the switch and the distributor? Like the early Dodges. Starts on 12, but runs on 6 volts.
Maybe the PTO and engine running or not are two separate issues. Possibly the seat switch is bad?
   / JD 317 will only run in the start position #3
Bad key switch? (Barn find - corrosion in key switch)
2015 CATERPILLAR 289D SKID STEER (A51242)
2015 CATERPILLAR...
Toro Z Master Mower (A50324)
Toro Z Master...
2016 Ford F-450 Ext. Cab Knapheide Flatbed Truck (A50323)
2016 Ford F-450...
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
Club Car (A50324)
Club Car (A50324)
2017 Ford F-150 Ext. Cab Pickup Truck (A50323)
2017 Ford F-150...
