JD 316 46 inch deck Spindle Question
   / JD 316 46 inch deck Spindle Question #1
OrtisEvans
Bronze Member
Laytonsville, MD
Ford NAA, Farnall Cub, Kubota B2100
I was disassembling the deck to paint it. I had to cut the bolts holding the spindles on sice JD used carriage bolts that spun when I tried to remove the nuts. The center spindle/hub came off easily. There must be a trick to removing the other two. What is the trick?
Ortis
   / JD 316 46 inch deck Spindle Question #2
You could weld a nut to the top and then hold it with a wrench. How to fix the holes? idk
Ortis
The answer turned out to be simple: hit it harder! A couple good whacks got the spindles out. As for the carriage bolts: yes, as mfreund suggests, i'll use a hex bolt and nut. No welding required.
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2023 John Deere RD40F Draper Head (A53342)
2023 John Deere...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
