JD 3150 diesel fuel lift pump.
   / JD 3150 diesel fuel lift pump. #1
bsrfarms97
John Deere 3150
Hey guys. Went out and started the jd today to move some compost and it had trouble starting. When it did it had a bad miss. Well I cracked all the injectors and noticed the number 2 wasn't right. Seems like the plunger is stuck open and leaking fuel down into the cylinder walls while it sets causeing it to be hard to start. Once it starts eventually it starts firing on all 6 and runs just fine. I've decided to replace number the 2 injector. What I'm wondering is can anyone tell me how much pressure is normal when checking the lift pump that feeds the fuel pump? Thanks and any help would be greatly appreciated.
   / JD 3150 diesel fuel lift pump. #2
The lift pump should supply 5 -7 psi.
2016 Clipper Sport 106 17FT S/A Pop Up Camper (A51694)
2016 Clipper Sport...
safety baskets (A53421)
safety baskets...
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
2002 Freightliner FL112 T/A E-One Pumper Fire Truck (A51692)
2002 Freightliner...
2014 TROXELL 130 BBL VACUUM TANK (A53843)
2014 TROXELL 130...
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
