JD 3150 diesel fuel lift pump.
   / JD 3150 diesel fuel lift pump. #1
bsrfarms97
John Deere 3150
Hey guys. Went out and started the jd today to move some compost and it had trouble starting. When it did it had a bad miss. Well I cracked all the injectors and noticed the number 2 wasn't right. Seems like the plunger is stuck open and leaking fuel down into the cylinder walls while it sets causeing it to be hard to start. Once it starts eventually it starts firing on all 6 and runs just fine. I've decided to replace number the 2 injector. What I'm wondering is can anyone tell me how much pressure is normal when checking the lift pump that feeds the fuel pump? Thanks and any help would be greatly appreciated.
   / JD 3150 diesel fuel lift pump. #2
The lift pump should supply 5 -7 psi.
2005 International 4200 VT365, Super Cab (A52384)
2005 International...
2016 Chevrolet Silverado 3500HD Knapheide Service Truck (A51692)
2016 Chevrolet...
2012 Kubota L5740 (A50123)
2012 Kubota L5740...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
