JD 3130 PTO brake
   / JD 3130 PTO brake #1
DLTTrekkers
Veteran Member
Paarl South Africa
I have a JD 3130 with a IPTO . The PTO shaft do not stop fully . The PTO brake and clutchpressure is 10 Bar. I have splitted the tractor and replaced the PTO brakeparts witch was badly worn .
My problem is ......PTO brake still do not stop the PTO shaft completely .
   / JD 3130 PTO brake #2
It's possible that the pto clutches are warped.
   / JD 3130 PTO brake
Before I closed the tractor I did feel the plates by putting the shaft in the PTO clutchpack and turned it by hand ....feeling the normal drag of the clutchplates....after essembly I felt the outer PTO shaft and that also felt normal .Where on this model can one adjust the pressure by say 2 bar upwards to a max of 12 bar ?
If I grab it by hand it stops !
   / JD 3130 PTO brake
Slow rotation wil happen when its equiped with a midshift coupler(DUALSTAGE CLUTCH) , but this model do not have it. Thats y its equiped with a PTO brake(to stop the shaft from rotating) Please help ?
   / JD 3130 PTO brake #6
Where is Paarl located? Maybe we are losing something in the translation ??
   / JD 3130 PTO brake
Paarl is about 200km (125miles)west north west from the most southern tip of Africa . But this wil not solve my problem !
   / JD 3130 PTO brake #8
I tried to fine PTO brake parts for the JD 3130 on the jdparts.com site, but none were listed. Unlike the PTO brake parts that are listed for my JD 4300.
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2011 Ford F-350 Enclosed Service Truck (A51692)
2011 Ford F-350...
2008 Ford E-350 Cargo Van (A51692)
2008 Ford E-350...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
