rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,985
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Everything checks out. Fan works, compressor seems fine, sight glass shows a normal charge. But the air it blows is not much cooler than outside.
First thing I should probably check is if the heat exchanger and control valve are clean and not insulated with a ton of dirt, chaff, and dust.... Where are those things located? What's the best access to clean it off?
Machine is a 2006 310SG
Thanks,
rScotty
Thanks,
rScotty
