DeepEastTexas
- Joined
- Aug 13, 2022
- Messages
- 3
- Tractor
- JD 3038E
All of you know where the water is coming from that accumulates in your tanks & cans.
The advent of corn alcohol added to our fuel has given us trouble since day one. Left sitting in cans or tanks the water in the alcohol separates & settled to the bottom of the tank.
Manufacturers changed fuel line types to address the first problem we encountered.
Carbs and injection systems rusting has been addressed but not 100% we still see clogs of slimy mess and rusty globs in bowls and metal tanks.
And yes there are growths in some fuels.
My 3038E tank is up for a clean out. How do I know? Filters new & water separator clean but it still runs about 10 minutes then quits. Two approaches: blow air thru line back into the tank( though this is a temporary fix) or remove tank and take supply line fixture then wash tank with high pressure. Be sure to clean the screen & dry out the tank. Replace and go to work!
Even the last fix is temporary unless you have access to non alcohol fuel!
