JD 3032-E Log Splitter
/ JD 3032-E Log Splitter #1
Hank Walters
Cottage Grove, Oregon
3032E
I just installed a DR 3-pt hitch log splitter on the 3032E and it works as advertized. A splitter with a 3-inch cylinder seems a good match for the 3032/38-E's 5.3 gpm hydraulic pump. Anything bigger would go way too slow. Cycle times depend on engine RPM, but I get 6.7 seconds extend and 5.6 seconds retract at 2500 rpm. At 1500 rpm (fast idle) the numbers are 10.9 sec and 9.1 sec. Since this is a dual action splitter you can split logs in both directions, saving lots of time.
Since JD doesn't sell a Power Beyond kit for this tractor yet, I searched the internet and found out how Woods Equipment attaches their backhoe: (see http://www.woodsequipment.com/uploadedFiles/Products/Manuals/MAN0998.pdf for details.)
I have an SCV kit on mine but was able to connect a power beyond outlet the same way, as shown in the attached photos. DR-Splitter.jpg1.jpg2.jpg3.jpg
Photo 1 shows where I disconnected the steel line from the side of the SCV assembly. Connect two "Quick-Connect" fittings as shown in Photo 2. Don't forget to connect a bypass loop when you are not using the splitter as shown in Photo 3.
I had to re-route the hoses on the splitter because they are too short if you lower the splitter to the ground. Turning the rear connections and mounting the hoses on the side of the splitter gives you enough length.
/ JD 3032-E Log Splitter #2
That's a great looking splitter! I want one!
/ JD 3032-E Log Splitter #3
Nice looking setup! How much did the splitter run you?
INOP/NON-RUNNING 2012 Ford F-450 Ambulance Truck, VIN # 1FD0X4GT2CEB23465 (A65563)
INOP/NON-RUNNING...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
2000 Chevrolet 1500 Conversion Van (A66408)
2000 Chevrolet...
2020 VOLVO VNL760 SLEEPER TRUCK (A59914)
2020 VOLVO VNL760...
2013 PROFAB 200BBL CRUDE TANKER (A65643)
2013 PROFAB 200BBL...
2021 Yanmar Diesel Engine (A65579)
2021 Yanmar Diesel...
