JD 3020 sputtering
   / JD 3020 sputtering #1
Thompsojrt
Salina, ks
JD 3020
I have an old gas 3020. It started up for me after a hard winter, but quickly sputtered dead. Then wouldn't restart....cranked but never engaged. I guessed bad gas, so drained it and put in new gas. Got it started, with a jump, but again it sputtered dead after a few minutes. I've checked battery and it's ok. Any suggestions on my issue/fix?
   / JD 3020 sputtering #2
Since it runs for a few minutes and then quits, I am guessing a fuel problem. It sounds like it is running off of the gas in the carburetor and it is not filling fast enough to keep running. The float in the carburetor may be stuck in the closed position or the fuel line from the tank may be clogged. Try disconnecting the line from the tank at the fuel pump and see how much flow you have there. If gas is flowing freely there, then the carb probably needs cleaning.
UNUSED CFG Industrial MY50R Mini Excavator (A47384)
UNUSED CFG...
72in Rock Bucket Skid Steer Attachment (A50322)
72in Rock Bucket...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
2019 John Deere 8295R MFWD Tractor (A50657)
2019 John Deere...
CRESCENT  MANIFOLD TRAILER (A50854)
CRESCENT MANIFOLD...
2001 Kubota L35 4WD Tractor Loader Backhoe (A49461)
2001 Kubota L35...
