jd 3020 leaky fittings
   / jd 3020 leaky fittings #1
wallypedal
Torrington Wyoming
JD 3020
Got a leaky fitting on a JD 3020. Pretty sure the seal is shot. What parts do I need and how tough is it to replace? Instructions somewhere?
On the other fitting, the metal between the balls is cracked, but doesn't affect anything right now.
Absolute rookie on this hydraulic stuff, but know how to twist wrenches.
Thanks!:confused:
   / jd 3020 leaky fittings #2
:welcome: to TBN, I would repost this in the JD forum. Might get some more help.
   / jd 3020 leaky fittings #3
Which fitting? Since you mentioned balls im thinking the scv hose connections. If this is it, its a very simple fix with an o-ring and backup plastic ring available at your deere dealer. The broken ball retainer is not a problem as long as its holding the hose in place.
   / jd 3020 leaky fittings #4
If it is that bad, then just get a new QD half.
   / jd 3020 leaky fittings #5
Since you didn't state yr model or SN I guessed your tractors SN was below <123,000. If it's leaking between the male coupler tip & receptacle these parts should correct the leak.
parts key #10 R26485 RING,BACK-UP ADD 2.94 USD
parts key #11 R59343 O-RING, PACKING ADD 1.58 USD
Thanks Tx Jim and others!
I went online to JD parts, put in the order with my local dealer, picking them up in half an hour. I've got the o-ring picks and know how to use them, so should be all set.
Wallypedal
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2024 KMC 7406 (A53084)
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
