jd 3020 Hard Starting Need help!!
   / jd 3020 Hard Starting Need help!! #1
schuyler co
LITTLETON IL
JD 3020 GAS 1965
I have 65 jd 3020 gas and have replaced distributor, cap, rotor, condenser, plugs, wires, points to no avail.......It wants to fire when ya fisrt try startn it but if ya don't get it to go then you either pull it or wait an hr or so......Really at wits end any thoughts or advives much needed!!!!
   / jd 3020 Hard Starting Need help!! #2
Maybe fuel related issue.. as long as you have spark given that you have replaced most everything related to spark.
I'd stop with the ether, tho.
Look into the carb and the fuel lines from tank to carb.
Assume you know that it has good compression.
   / jd 3020 Hard Starting Need help!! #3
Have you considered changing to electronic ignition in lieu of points?
   / jd 3020 Hard Starting Need help!! #4
I agree, it's likely a problem with the carb.
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2016 HITACHI ZAXIS 210LC-6N EXCAVATOR (A51242)
2016 HITACHI ZAXIS...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
