jd 3020 Hard Starting Need help!!
   / jd 3020 Hard Starting Need help!! #1
schuyler co
LITTLETON IL
JD 3020 GAS 1965
I have 65 jd 3020 gas and have replaced distributor, cap, rotor, condenser, plugs, wires, points to no avail.......It wants to fire when ya fisrt try startn it but if ya don't get it to go then you either pull it or wait an hr or so......Really at wits end any thoughts or advives much needed!!!!
   / jd 3020 Hard Starting Need help!! #2
Maybe fuel related issue.. as long as you have spark given that you have replaced most everything related to spark.
I'd stop with the ether, tho.
Look into the carb and the fuel lines from tank to carb.
Assume you know that it has good compression.
   / jd 3020 Hard Starting Need help!! #3
Have you considered changing to electronic ignition in lieu of points?
   / jd 3020 Hard Starting Need help!! #4
I agree, it's likely a problem with the carb.
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A51039)
2016 KBH...
INGERSOLL RAND 100KW GENERATOR (A50854)
INGERSOLL RAND...
2004 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2004 STERLING...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
