JD 301A hydraulic trouble
   / JD 301A hydraulic trouble #1
Tilb
JD 301A. Case 800
Hello, I was cleaning up some trees and brush with my JD 301A and it was working great, I was pushing the the last trees into the pile when my hydraulics quit working. I am still able to use the direction reverser and drive the tractor and the brakes still work but no steering or hydraulic operation. I changed hydraulic fluid and filter, cleaned screen in resivor, disconnected the line that feeds the front pump and have no fluid coming through the line. Does anyone have suggestions where to look next? Thanks for the help
   / JD 301A hydraulic trouble #2
Welcome to TBN
If reverser & brakes operate correctly then trans pump must be pumping oil. Check frt pump coupler to be sure it's not stripped & frt pump shaft is turning when engine crankshaft turns.
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
2008 Ford F-250 Reading Service Truck (A59230)
2008 Ford F-250...
