JD 3010D Starter/Ignition Switch
/ JD 3010D Starter/Ignition Switch #1
John Deere 112, John Deere 3010D
I recently purchased a John Deere 3010 Diesel that had been sitting for several years. It is a 24 volt system. I have replaced the voltage regulator, solenoid and batteries. Also, I have had both the generator and the starter rebuilt. It doesn't want to start now. When I crank the engine it doesn't crank very hard and when I back the key off to the "off" position it keeps cranking, but at a much slower rate. I then have to disconneect the battery. So it seems to me that if the starter doesn't stop cranking the current must not be cutting off at the switch. How do I test the switch? I have a multimeter with an ohms setting. Currently, I get continuity when I test between ST and BATA, but the continuity does shut off when I turn the switch off. However, I don't get continuity between ST and BATB when I turn the key. Can someone please help me make sense of this?
Thanks
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
6' 3Pt Disk (A66285)
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
ATTENTION PLEASE READ (A64126)
ATTENTION PLEASE...
