JD 3010D Starter/Ignition Switch
   / JD 3010D Starter/Ignition Switch #1
John Deere 112, John Deere 3010D
I recently purchased a John Deere 3010 Diesel that had been sitting for several years. It is a 24 volt system. I have replaced the voltage regulator, solenoid and batteries. Also, I have had both the generator and the starter rebuilt. It doesn't want to start now. When I crank the engine it doesn't crank very hard and when I back the key off to the "off" position it keeps cranking, but at a much slower rate. I then have to disconneect the battery. So it seems to me that if the starter doesn't stop cranking the current must not be cutting off at the switch. How do I test the switch? I have a multimeter with an ohms setting. Currently, I get continuity when I test between ST and BATA, but the continuity does shut off when I turn the switch off. However, I don't get continuity between ST and BATB when I turn the key. Can someone please help me make sense of this?
43030 (A51691)
43030 (A51691)
2014 10ft T/A Dump Trailer (A51692)
2014 10ft T/A Dump...
2021 Ford F-250 4x4 Ext. Cab RKI Service Truck (A52377)
2021 Ford F-250...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500...
