JD 3010 Timing Mark
   / JD 3010 Timing Mark #1
Luray Farmer
I'd like to check the timing on my 3010. I slipped the access plate aside and have a clear view of the flywheel. But I can see no timing marks of any kind. What am I looking for exactly?
Bill Shields
Luray, VA
   / JD 3010 Timing Mark #2
As you are looking in the access hole, there should be a mark on the left side of the opening. You might need to clean off some clutch dirt and dust from the casting to see it. Then on the surface of the flywheel, there should be a few marks around the diameter designating TDC, 10 degrees, 14 degrees, 120 degrees and 240 degrees if diesel, and at least TDC, and 26 degrees for a gas engine.
Great, thanks, that's very helpful. I'll give it a shot this weekend. The motor now runs fine with a new Zenith carb, but I'd like to know if the timing is right.
2021 Doyle 8 Ton Trailer Tender (A52748)
2021 Doyle 8 Ton...
2010 International 4400 National Crane 300C 56ft 8 Ton Crane Truck (A50323)
2010 International...
2018 Kinze 3500 Planter (A52349)
2018 Kinze 3500...
2004 Mercedes Benz E-Class Sedan (A50324)
2004 Mercedes Benz...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52748)
2014 Dodge Ram...
2016 Isuzu NPR-HD Morgan 24ft Box Truck (A50323)
2016 Isuzu NPR-HD...
